Have used them all from no-name (WALMART, etc) to Prestone and OEM labels. I usually flush every 2-3 years and have never noticed a difference. Bottom line is not leaving it in too long is the key.
I finally switched to the 5 yr prestone. Only 1.5 years so far but it looks good thus-far. I had the long term fluid in the Marauder from ford and that stayed clean untill I finally changed it.
The key there is to record the date needed for a change. A notbook in the glove or paint the radiator.
03 Marauder DPB, HS, 6disk, Organizer Mods> LED's in & Out, M&Z rear control arms, Oil deflector, U-Haul Trans Pan, Blue Fuzzy Dice 02 SL500 Silver Arrow 08 TC Signature Limited, HID's Mods>06 Mustang Bullet Rims 235/55-17 Z rated BFG G-Force Comp-2 A/S Plus, Addco 1" rear Sway, Posi Carrier, Compustar Remote Start, floor liners, trunk organizer, Two part Sun Visors, B&M Trans drain Plug, Winter=05 Mustang GT rims, Nokian Hakkapeliitta R-2 235/55-17 12 Escape Limited V6 AWD, 225/65R17 Vredestein Quatrac Pro, Winter 235/70-16 Conti Viking Contact7 Mods>Beamtech LED headlight bulbs, Husky floor liners
I use the supertech (walmart) 50/50 pour and go stuff. I typically have to replace a hose or something before the typical 5 years is up so meh. cheap stuff works fine. If you're racing... water and Royal Purple's Purple ICE really works well from what I've seen (no experience myself though).
yea whatever cheapest......i prefer the green stuff
optimally you want to use distilled water instead of filling from the hose. That actually makes more difference than the antifreeze brand. The distilled water won't form crusty deposits in the cooling system like tap water does.
That was the G05 no? If anything, that stuff is the closest to the old green for general compatability. Price is even reasonable for it at the parts store. Old green is hard to find around here, just about everybody only stocks the compatable with everything stuff, or long life forumulas.
deathcool........that shit turns to rock candy looking crap!
Deathcool is wierd. it gets chunky if you mix it with anything else. I flushed that stuff out of my S10 years ago. People say the 4,3 has intake gasket problems where it starts pissing coolant out. Mine hasn't had any problems with that. I can't help but suspect the lack of problems and the lack of Deathcool are related.
