And make sure the distributor has the right kind of gear. non-roller distributors have iron gears, roller distributors have steel. They physically interchange, but the iron part gives up when in contact with steel. If a CFI dizzy goes into a roller cam car, the distributor gear gets wiped out. If a roller cam distributor goes into a flat tappet cam car, the cam gets wiped out. One of these things is more difficult to deal with than the other, but neither is desirable. You really don't want to dump a bunch of metal shavings in the oil.
the '85 won't start, hooray! now I can try to fix it
So far so good!
Lol... nah, I did have one CFI/cast gear dizzy with the spares but I segregated that one far far away from the two steel gear onesPete ::::>>> resident LED addict and CFI defector LED bulb replacements
I figure you know that, but I posted that for future reference purposes in case someone comes across this post when searching for a solution.86 Lincoln Town Car (Galactica).
That's what I figured - good call, we don't want anyone to make that mistake!
I only recently figured out what the spare ones I have are... since the 85 had been acting up. I love it when I am forced to learn things this way... my laziness tends to hold me back otherwisePete ::::>>> resident LED addict and CFI defector LED bulb replacements
understand that. There are a lot of semi-broken things around here that I sort of go "f it, its working enough" to.86 Lincoln Town Car (Galactica).
yea i need to harvest more spares myself.
