Hi guys. I didn't know where to put this, but I thought I'd give you a little info on the belts, and their part numbers. Apparantly both belts have applications that are available at your parts store...
The first, the 505k6, the 3g Alternator belt (slightly longer than stock belt so it's easier to swing the belt over the alternator pulley). You can find this if you have your parts person look up a 2002 Ford Escort 2.0 SOHC engine with Air conditioning. Roughly About 23 bucks, more or less depending on where you normally shop...
Second, for all you A/C lovers is 560k6. This can be found if you ask the parts person look up a 1997 Dodge Caravan with a 2.4 engine with air conditioning. Roughly about 19 bucks, more or less depending on where you normally shop...
