engine transplant questions
    It looks like the engine in my wife's Town car is having issues. While it just may just need some fixin'. biggest thing is I am getting a coolant leak that seems like is behind the water pump, bypass hose??? also it does not want to downshift, I can floor it but will not go into passing gear. That may be tranny problems. But it got me thinking that I may just work on another engine to put in when this one finally gives up. I am thinking of an Explorer V8 GT-40 engine and do some performance work to it. For my drag week project. While the town car is stock 89. What would I need to drop in a GT-40 Explorer motor. I do realize it is a direct transplant, physically. But what electronically would I need. Would I need to do a mass air swap. Would a mustang ECU handle it or would I need something else?
    Thanks all
    Tim
    84 Lincoln Town car signature, R.I.P
    85 Ford LTD Crown Victoria 2 door performance project
    89 Lincoln town car: RIP
    89 Crown Victoria LX 2002 USACi sound quality world champion RIP
    1990 Mercury Grand Marquis LS
    1994 Mercury Grand Marquis (sold)
    2004 Mercury Marauder. owned for a week then got screwed by the dealer
    Originally posted by over2tonsofFun View Post
    It does not want to downshift, I can floor it but will not go into passing gear. That may be tranny problems.
    Sounds like the plastic grommet may have broken. Also check the fluid level.
    '79 Continental Town Car
    '90 Crown Victoria LTD
    '94 Crown Victoria
      http://www.lincolnsonline.com/tech/00052.html
      see that article.
      If the TV bushing has failed... you're probably killing your trans if it's not already about to die.
        Thanks, I will look at that and may just replace it anyway, just to be safe.
        Tim
          GREAT idea! Bobby
            well, for one id swap that cam out to soemthign alittle better, like a HO cam or soemthing. for tourqe a XE258. for computer a DA1 or D9s works quite fine for non MAF. throw some good headers on it, a bored EGR spacer or lightning, or markvii cables, youl be all set.
              Well I checked with my local stealer, $39. I got it from fordpartsgiant.com for $7.57. under 20 shipped.
              Tim
                UPDATE:
                Fordpartsgiant wanted to sell me the bulk pack of 4. so around $40 again. So I found tousleyfordparts a dealer in MN. The part shipped today, total cost shipped: $10.51 ( 6.51 for the part 4.00 shipping) cannot beat that that with a stick.
                Tim
                    yah they come in a 4 pack, and not all places want to split them up. Kind of silly really.
                      Well the bushing worked.
                        Good. That stupid bushing causes more trouble than it has a right to.
                          Well as I was typing the above post. I get a call from my wife. the car died out on a test drive. So I go out and see. I will only run for a little bit but then chugs and dies. When you try and start it again, it cranks then bogs down while cranking. I am afraid it is a head gasket. could this be a symptom of a head gasket??
                          Tim
                            check the oil for milk.
                              I haven't checked the oil yet. The wife said that as soon as it started to act up there was smoke out the back. I noticed some greyish smoke out the driver tailpipe.
                              Tim
