I have an 85 marq with the awesome cfi I have taken out the cats changed damn near every sensor tuned it up and my question is can i bump the ignition timing? and if so any particulars 10 degrees btdc or ? dont wana go crazy trying for some more mpgs
1985 grand marquis CFI igntition timing question
CFI is typically really pissy about timing. Bump it 1-2 degrees at a time and drive it around. If it pings, go back to the last setting.
It has more to do with the programming in the computer. It's very aggressive IIRC. Just know that CFI usually won't take well to timing changes like EFI can.
the most timing i got with my old 84 cfi was 12 and it seemed to like it but the fp up it should make a big help.1984 mercury grand marquis ls rebuilt 306 flat top pistons with factory cfi and lincoln headers with single glasspack dual snorkle air cleaner. Gloss black paint with slick top coversion.
1986 mercury grand marquis colony park 5.0 sefi dual exhuast thrush turbos with h pipe and turbines
The CFI tends to run a little on the lean side, and it is a little more agressive with the timing than SEFI so it may not take much advance. Make sure its correct first, then try advancing it 2 degrees at a time until it pings, then back off 2 degrees to make sure it doesn't rattle. Don't be too surprised if it won't go very much past the stock values.86 Lincoln Town Car (Galactica).
My 85 used to ping at 8 degrees on premium gas. After the SEFI swap, I have it at 14 degrees and it runs great on regular gas... all the ignition parts are the same, I didn't even have to pull and re-set the distributor. Unless I had some bad CFI wiring, it was just the CFI. lol...
I actually read a TSB for CFI cars that advised to retard the timing, which is why I did it.Pete ::::>>> resident LED addict and CFI defector LED bulb replacements
