timing chain replacement
    Originally posted by blazingstang
    gear drive
    Gear Drive
    GeAr DrIvE
    GEAR DRIVE
    GEAR DRIVE
    GEAR DRIVE
    My 351 has gear drives.
      gear drive
      Gear Drive
      GeAr DrIvE
      GEAR DRIVE
      GEAR DRIVE
      GEAR DRIVE
      yes the louder the better!!!!!!!!!!!!
      I've yet to order mine yet thouhg
      damned tool bills
      GMNRadio DJ, Podcast Co-Host
      95 S10 93 Accord
        oh, yea, i get to do the Timing BELT on the ranger this afternoon
        Yay, gotta pull the radiator out :/
        damn newer vehicles and no space
        Least it only has 1 cam
        95 S10 93 Accord
          You should snag that ford motorsport adjustable timing chain, and advance your HO cam 4 degrees when you do it...
            plenty of room under the hood of a ranger
            i had a 92 olds with a 24v 3.4 dropped off today for a mystery clunk in the engine area eek!!!!
              so, got it all mostly done, got the belt replaced and everything's hangin around. i've probably only worked on it about 2 hours today, taking my time
              yup plenty of room in a ranger after getting the radiator out (MUCH easier than i thought earlier)
              I'm impressed, only 1 thing broke, and that was part of a bracket for an ac hose, and the part that broke was insignificant to the operation of the bracket
              belt wasnt even that bad. the cam was about 3 degrees retarded, so the belt was a tad worn. the serpintine belt wasnt all that bad either. not bad considering they're both original (110k)
              i'll button everything up tommorow and getrdone
              95 S10 93 Accord
                My uncle showed me a V8 engine out of an Olds Aurora he had to swap. That thing has got to be worse than the Cutlass. Changing the starter requires removal of the intake manifold.
