timing chain replacement
    I'm just curious at this point. I'm trying to figure out how to fix this weird idle issue.
    Stock EFI 302 w/ about 168,000 miles. No trouble codes are being thrown. All maintenance was done this spring (plugs, wires, etc.). Running out of ideas for a fix.
    What is the procedure to replace the timing chain and gears? Any special tools needed? What else should be done (water pump, front seal, etc?)? How big of a job is it for someone who hasn't done it before? How long would be too long for a shop to do it?
    Should I stick with a new stock chain and gears or go with something else? I thought someone once said we could use the mustang chain and gears on these cars. Does it matter?
    I'll check with the two places I do business with in town and let you guys know what they will run me for cost. I want to do it myself if at all possible.
    I'm not sure I'd go straight to timing chain. But generally here is how it's done
    Special tools: harmonic balancer puller
    Other things you should replace while this is apart: front crank seal, water pump.
    If you've got a shop manual it should give better instructions, but essentially, you pull the brackets off the front of the motor. Pull the water pump, then you can access all the timing cover bolts. Remove the crank pulley, pull the balancer. Remove all the timing cover bolts including the two front oil pan bolts. Timing cover will then pop off. Turn the crankshaft untill the dot on the cam gear and the dot on the crank gear align. Unbolt the 3 cam gear bolts, smack the gear with a rubber mallet and it'll come off. Chain just comes right off, and you can slide the lower gear off. Install is reverse. I'd reccomend a double roller timing chain as a replacement. Just request one for an 88 Mustang and it should be a double roller unit. You can tell because the gears for a double roller chain have two narrow rows of teeth vs a single wide tooth. Double roller chains stretch less over time.
    What exactly have you done to correct the idle issue? And whats it doing? I read in your other thread rough idle and its using more gas. I'd think about checking the fuel pressure, and checking to see if you have a leak in the system somewhere. With the fuel pressure guage hooked up, shut the motor off. The pressure should hold pretty steady. If it falls off, you have a leaky injector or a bad regulator or something.
      heres what u can do to check the chain for slack
      15/16" socket on the crank bolt
      turn ignition off
      pull the coil wire
      pull off the dist cap and pull it aside
      now move the crankshaft clockwise till the rotor moves
      now move counterclockwise.....if the chain is tight, the rotor will move right away........you will be able to telll if theres alot of play
        Thanks for the info, guys. I'm more or less just getting the info so I'm more prepared if the problem needs fixing.
          If you do that, might as well convert to HO
            :stupid:
            '80 Town Coupé
              Yeah, if you have the timing chain off, its literally just another bolt to get the cam out. You'll need to take the intake off to remove the lifters though, and for a proper conversion you need to change the heads, tho its not absolutely needed.
                Well, if I'm able to get that job down the street I'll start tearing things apart since I wouldn't have to drive to work. Headers and cat removal could be done. And if I can afford it I may consider the HO conversion.
                *crosses fingers for job down the street*
                  timing chain isnt for the beginner... i found out the hard way, lol
                    At 168K mi, can't we be pretty sure there wil be play? With this method, how much is "too much"? My chain seemed sloppy at half that mileage.
                    FOR SALE: 89 Grand Marquis GS HO. Quarter mile = 15.8 @ 87mph -- pics http://public.fotki.com/vfr700f2/car...rcycl/mercury/
                    Junkyard HO, MSD wires, stock Mustang headers, off-road H, Hemi Super Turbos. 3.55 trac loc, HO governor and servo in stock rebuilt AOD. 3-row rad, air pump delete, cop rear bar, wagon rear springs, 93 CV rear discs, 98-02 Grand Marquis wheels, Class 3 hitch, aluminum space-saver spare.
                    Coming soon: 98-02 front brakes, cop springs, Monroe cop shocks, 96 Cobra wheels w/255/50/17. Better yet, need a nice wagon to put all that stuff in.
                      Kevin's car is a freak tho
                        somebody should put up a timing chain replacement procedure with pictures "hint hint"
                          I think two guys named Chilton and Haynes did. If not, I'm sure Henry's buddy Helm has.
                            BTW... once the timing chain is off, there are TWO bolts that hold the cam retainer plate on.
                              gear drive
                              Gear Drive
                              GeAr DrIvE
                              GEAR DRIVE
                              GEAR DRIVE
                              GEAR DRIVE
                              2008 Mercury Grand Marquis GS Bone Stock
                              The modern definition of "racist" is "someone who is arguing with a Liberal".--updated Peter Brimelow quote.
