So odd that I wanted to share.
The cruise went out a couple years ago on the 91, and I'm shamefully just now fixing it because I'm taking that one to the festivities this year.
After checking the fuses again, I stared at the ball and scratched my head for a while. I decided to try to give the far side of the ball some vacuum and see if it pulled the cable. I didn't even know if this was a legit test at the time, but it is. I saw the throttle end of the cable move a tad but that was it. So I tried to push on that end of the cable, it moved just a tad too. Cable's frozen? Nope, I took it loose and it moves back and forth.
It turned out that when the cruise cable was trying to move the throttle, the throttle cable's collar/spring assembly that's between the throttle lever and both cables' mounting bracket was cocking out and binding up, not letting the cruise pull.
When I had pulled the cable cover off the ball, I thought the little linkage flopping around looked odd. Sure enough it was an anchor for the mechanism that pulled on the cable. No doubt it broke itself trying to pull on the bound up throttle cable! I tried using my hand to keep the throttle cable strait and pressed on the cruise cable, and it moved freely. For now I just used a zip tie to cinch the two cables together a little, just until I decide to do anything else about it
Luckily I had a newer box model cruise ball in the basement, leftover from when I did the SEFI swap on the 85. I applied vacuum to the far side of the ball again and Vroom! I have cruise once again.
Fair chance this could happen to someone else, so keep it in the back of your mind
