I was musing on how my car seems neutered in denver, colorado, the "mile high city."
The same power cruising, but when you floor it to 3500-4000rpms, it just... doesn't go.
Hoping that's just the altitude.
I have converted to massair.
But anyway, while massair should accomodate thinner air, does speed density have a means to calibrate itself to the higher altitude?
It has air temperature, it has throttle position, and vacuum readings [map]; with thinner air, the engine might pull less vacuum (on top of the lower outside pressure) than at sea level?
