code 63
    code 63
    Allright guys I have got a code 63 the past few tomes I've checked codes any way of fixing it short of getting a new TPS
    check to see what the voltage actually is. If its below 0.6 volts, remove the TPS to see if the ears are busted off. If they are, you have to replace it. If its not, see if the voltage increases properly when opening the throttle.
      Sorry guys bout the double post my phone didn't act like it sent the new thread out so I did it again
