Hey guys, I've gotta '88 grand marquis sefi 5.0 and I need y'alls advice to tighten the passenger side manifold to downpipe bolts cause the exhaust is leaking I have tried a deep socket to try and tighten it along with a wrench and neither would do it
Exhaust Question
you need a swivel socket or a socket with a u-joint........also a good idea to heat up the net with a torch
harbor freight has swivel impact socket sets cheap. you need 5/8" or 16mm take your pick
