Spout Connector Cut
    Spout Connector Cut
    Hey Guys, One side of my spout connector has been cut on my 88 Grand Marquis it is still there just cut. Can I just solder it back together and then heat shrink it? or will that have too much resistance? Weird that it hasn't had any bad issues just want to fix it. Thanks
    Soldering should be fine, a good joint is about 0 ohms.
    The ECU can limp with no SPOUT signal, but you lose spark advance and dwell control. So you'll get more power, easier starts, and maybe better fuel economy with the SPOUT connected.
    You'll want to check the base ignition timing too. If there's any scenario in which reconnecting SPOUT could possibly be bad, it's one in which the base timing is way off...
    1985 Wagon Queen Family Truckster.
    Get It ==G|== Together
      how do I set the base timing I have a timing light
        Usually, the proper timing spec is marked on the balancer. If not, you may have to go under and clean the balancer and put your own mark at 10 degrees before top dead center. On the passenger side of the engine, there will be a pointer on the timing cover, right by the crankshaft pulley. This is your timing pointer.
        Hook the timing light to cylinder 1's spark plug wire. Marked with a number '1' on the cap.
        Remove the spout connector (yours is already removed :p ), start the engine, shine the light at the pointer, it should light up at your mark.
        If not, shut the car off. Loosen the distributor bolt (1/2" socket or wrench however you can get to it). Restart the engine, with the timing light in one hand, and the distributor in the other, rotate it however you can to set the timing to the mark for 10BTDC. It would help if you have an extra person at this point. Shut off the car, and tighten the hold down. Restart the car and check the timing. It should be in the same place. If not, do it again. When you have set the base timing, reconnect the spout. Check timing again. The dot should move all over the place as the computer advances and retards the ignition timing.
        Good luck.
          I usually suggest a chalk or paint line on the balancer at the 10BTDC line so you can see it. Its really hard to see otherwise. Just be sure its on the BTDC side, not the ATDC side of zero.
            I used some steel wool to clean up the balancer and then put white out over the 10BTDC mark and wiped the excess off, it worked great for me.
              I set it at 10 BTDC And it runs like Shit dies at stop signs the spout being hooked up made it worse so I need to know what to do
                you're sure its 10BTDC and not 10ATDC? What was it before ?
                  I don't know
                    I know for sure I set it at 10 BTDC
                      any computer codes?
                        Did you disconnected the SPOUT when setting the timing and reconnect it after? That's the process, it should say so on the emission control sticker.
                        If you set timing with the SPOUT connected, it'll be way off.
                        Is this car basically stock? Or does it have a history -- like an engine swap that maybe left you with a mismatched engine and ECU, anything like that?
                          havent checked codes. Yes I pulled the spout before I timed it. The car is original, same motor and trans that came in it.
                            Original is good. Did the SPOUT get cut by accident or is it possible someone cut it on purpose? Not that I know what that would imply.
                            Did the timing go all over the place when you reconnected SPOUT? That would confirm it's a good solder, the timing will bounce all over if the computer is able to control it.
                              I got two KOEO codes, 33 and 63.33 is from my egr not being hooked up via vacuum and Idk bout the TPS circuit out of range low. and I got six KOER codes. I got a 12,13,18,33,44,94. I took my smog pump off so 44 and 94 are from that.12 and 13 are rpm not within test range codes, 18 is the spout circuit open,and 33 is egr related
