I just removed my smog pump. Patched the exhaust holes, plugged the holes in the heads, got the shorty belt, etc.
One question still, and I've searched a bit but didn't find a definitive answer.
There is a green vacuum line that goes from the EGR valve to the little 4-hose vacuum line connector that mostly connects to smog pump stuff. From there it continues to a bracket on the passenger inner fender with several solenoid-looking items.
I bypassed the 4-hose connector and connected the EGR vacuum hose directly to the solenoid (the one that it ultimately connects to). I capped off the other side of the solenoid since it went to one of the removed smog lines.
It seems to run fine but I don't think this is right since there is now no vacuum pulling on the EGR valve. Where should I connect the EGR vacuum line?
