Found Major Fuel Leak. Help.
    Hey guys so I found my fuel leak on the passenger side right next to the control arms. Its is PISSING out now touching the exhaust manifold. The piece of line thats leaking it a straight piece I'm sure I can cut 2" off the line and replace it but I don't have the cash to tow it to my school to fix it so how and what would I need to repair and fix this little problem. Thanks.
    compression fittings are your friend in this case. if you've got flaring tools. I would just cut a piece out and buy a length of line with some compression fittings from the local parts store, and drive it to your school to replace the entire length of line (when lines rot, it's usually a domino effect...this one goes then that one and then this other one)
      you could wrap some fuel line around the leaky spot just so it's not pissing on the exhaust so you can piss fuel on the frame and ground instead and just drive it to school to work on.
      of course... if you put a radiator clamp on it right at the hole... it might even temp seal it enough to only drip mildly or even stop it.
        cut the steel line and splice in some rubber fuel injection hose. Clamp it in place, go. Passenger side is the feed, so its high pressure over there. Make sure the line you buy is rated for fuel injection, not carb pressures. ~40 psi minimum.
          So I was right!
          That's actually the first place my old 91 marq started leaking gas, then it was the return on the drivers side under the a-pillar that went.
          I replaced all the lines with high pressure rubber fuel hose, still look good to this day.
            I'm starting to think when its time to do the fuel lines on my car (and thats getting soon), I might take a page from the Mark VII's book and use the plastic line. Not totally sure I like the idea of rubber but the plastic has held up OK on the Mark. Its expensive, but it certainly isn't going to rust.
              Great info guys. Its in a tricky spot so I'll try to deflect the leak of the exhaust just enough to drive it to school. Great idea's guys thanks.
                The way stuff rusts up there, those lines would just disintegrate if he tried anything like that, lol
                  They do make that tool that allows you to connect those plastic lines to anything, even factory Ford quick disconnects. You could probably make that come out factory quality.
                    What size line would I need to get.
