Someone told me the fuel system should remain pressurized for a significant amount of time.
I haven't tested exactly how long, but I know that after an hour, there's no pressure at all. I know, because I went to bleed off the pressure the other day before doing the fuel filter, and there was none there to bleed! Swapped the filter, no 40psi squirt of gasoline.
Is it supposed to hold pressure longer than that, longer than an hour?
If it isn't, what's wrong, and is it a problem?
A friend says it's the residual check valve built into the pump, and that the only symptom might be a slow crank. If that's it, then, I won't worry.
Let me know however if I need to look further into this.
Or if other problems might arise with the pump.
I don't smell fuel anywhere, so I shouldn't imagine that there's a leak. But I'm not really sure how to check for a leak, but if I can put fluorescent dye in and check it after 2 minutes running, maybe I can try that.
