pull the vacuum line to the EGR... pull a vacuum on it to open it with the car idling... if the engine dies, the valve itself is good and the passages are clear enough. If nothing changes... the passages are clogged or the valve is crap.
89 Grand Marquis hesitation off idle, Where to look?
I had the same light throttle hesitation on my '90. Here's what cured it.
Cleaned out the throttle body/butterfly and iac. Replaced the vacuum line coming from under the plenum to the map, also replaced the vacuum line coming from under the plenum and going down the front of the engine under the a/c compressor to what I believe is the evap solenoid. Both vacuum lines were pretty bad. I also ran two bottles of chevron techron fuel cleaner with 2 tanks of gas.
Light throttle miss and rolling idle are gone.
Too bad you can't replace the vac lines without removing the intake......
the MAP line you can... the EVAP, vac tree, and PCV lines not so much.
plenum is the big upper metal section of the air intake
