Will this work? I might be able to get a 98 Explorer engine, and can probably get him to throw in the computer from the car too. But will it work?
Explorer computer?
wont work cogsworth........exploders are eecV it would be a shitload of work to convert
i will keep me eyes peeled for mark 7 ecm's to harvest.......be about 35 shipped for one dude
scott
Originally posted by lincolnmaniawont work cogsworth........exploders are eecV it would be a shitload of work to convert
scott
i said that...LOL
Swap all the stuff on the front of the motor, put a distributor in, fuel rail, valve covers, coolant tubes, drill and tap the intake manifold for the air charge temp sensor, and a few other things...Builder/Owner of Badass Panther Wagons
Originally posted by CogsOkay. Is this expolorer engine going to bolt right in? Is it going to work with the Mk. 7 ECM? Will I need to modify anything other than turning the intake around?
Originally posted by MercracerOriginally posted by CogsOkay. Is this expolorer engine going to bolt right in? Is it going to work with the Mk. 7 ECM? Will I need to modify anything other than turning the intake around?http://secondhandracing.com/Home.aspx
Well, forget this guy...He want's me to just buy the block and heads for $550. I'll probably just stick with a regular Mustang engine. It would have only been worth it to spend almost all of my current moneys on it if it were a complete engine, minus accessories of course. Anyway, I should be able to get a Mustang engine cheap enough and throw some new gaskets and oil pump on and what not.
Thanks for the help though, guys.
i paid $500 for my assembled 0.030" over 351 short block with a set of E7 heads, a full Fel-Pro gasket set, and a ARP accesory bolt kit.http://secondhandracing.com/Home.aspx
Originally posted by CogsOh, and btw, the guy wasn't even willing to throw in the stock exhaust manifolds or the stock computer(before I knew i wouldnt even work) in the deal. Good luck selling those...86 Lincoln Town Car (Galactica).
Well, Scott told me I couldn't use my current headers because of the angle of the spark plugs on the GT40P heads, so since I don't want to buy the Motorsport headers, I figured I'd temporarily use the stock crap. No worries now though...I'm not getting that engine anymore. I'm on the lookout for a decent engine now though, so if anyone comes across one in the Chicago area cheap..let me know.
