Whats this part called..
    Somy 1991 GM sprung a coolent leak. At first glance I thought it was the intake gasket But after testing found a strem of water running from this little hose in the back... seems to run under the fuel line. should be able to see it in the attached picture.Click image for larger version
    That's one of the EGR spacer cooler (HEATER) hoses. Replace both.
      Wonder if '87 GM's have those hoses?
        If its fuel injected, yes.
        Alex.
          Is that question for me? If so, YES!
            CFI and EFI cars have that, or nearly that. 1/4" fuel line is the proper size IIRC. Replace both sides of it. The other end is on the opposite back corner of the lower intake on a hose barb. They meet at the spacer behind the throttle body.
