I didn't mix the bolts up (they're still in their original holes in the water pump), so let's get that out of the way first
I've seen different websites and different books list contradictory information regarding the front cover and water pump bolts - Some say just use engine oil on the front cover thread and non-hardening sealer on the water pump bolts (as well as the intake manifold bolts, FWIW) - Other say to use sealer on the front cover and nothing on the water pump bolts.
What's the deal? The car is my 90, so it's an SEFI, no fuel pump to worry about. What do you use on the threads of what bolts when you're doing the timing chain?
How about on the intake manifold bolts? Use sealer on those too?
My plan was to use the sealer on anything near the water passages in the front cover, and on all of the WP bolts. There's slight pitting around the passages but you can't feel any irregularities with your finger running across the gasket surface, I was going to put a thin film of RTV on the timing cover around those passages just to be safe. Also going to put some RTV in the keyway of the balancer when it goes on.
What say you?
What say you?
