Anybody have a computer?
    Does anyone here have an extra mustang or mark vii computer I could borrow to test my car? I have an 86 or 87 mustang computer in it now and with a new fuel pump and tfi module I still have a miss up top where the engine is cutting out.
    -Matt
    high RPM miss sounds like fuel starving or maybe bad wires or coil. See if you can borrow a fuel pressure guage that you can somehow set in a position to watch while running. At idle it should be around 30 psi with the regulator vacuum line connected, around 40 with it disconnected. it should maintain that range while driving too. Also, how old is the fuel filter?
      I have a spare 86 GT Comp....
