removing crank fan
    there are no fasteners on the 88-91 grills. It pushes in. Press it from the back side and it should pop out. Start at one end and work your way to the other.
      i shall!
        Whoever said you needed to remove the grille lies through his teeth! there is PLENTY of room to spare, the grille doesn't need to come off at all. Just took the cam out to the car and it fits perfectly between the water pump and grille.....there will be even more room when the water pump is gone.
        john:
        that's all you're getting for now :P
        goddamn rusting valve covers. i need to get my 1" spacer cut in half and planed so it's flat, need to install my finned covers.
        crank pulley is a bit rusty, too. the rust will probably fling itself off once it's started but i'll go over it real lightly with sandpaper
          HD Cast Iron Water pump is going in place of that aluminum one I hope... Spray the fuck out of those bolts, they look really fuckin rusty.
            the aluminum one is fairly new. replaced it the winter before last and it works great for now, cost 60 bucks and was nearly impossible to find locally. the OEM one was the HD i believe, there are 2 bolts in the difference.
            when this pump goes south i'll get the HD version but i'm not replacing it until then.
            been spraying the bolts regularly, i started them out today just to make sure they would come out. i'll wire wheel them all before they go back in - do any of them need a sealant, or am i good with anti seize on all of em?
            does the backing plate get a sealer on either side? or just the gaskets?
            don't know why they got so goddamn rusty. they didn't go in that long ago, last winter. the guy that used to fix my car for me probably didn't clean the bolts up when he installed it.
            the bypass and upper hose outlets are a bit rusty but the pump isn't rusty inside, gonna de-rust everything before it goes back on anyway.
            i've never taken the crank pulley off of anything. i have the feeling it's going to fight me
              been spraying the bolts regularly, i started them out today just to make sure. i'll wire wheel them all before they go back in - do any of them need a sealant, or am i good with anti seize on all of em?
              Antiseize will help. Crank pulley comes off with 4 bolts. The bitch is the balancer behind the pulley. Big ass bolt and washer. use impact gun to break it free. Then you're gonna need a balancer puller. Replace the balancer as it's probably fucked from being original...
              Leave backing plate alone!!
                gaskets only then.
                i made a steering wheel puller a while back. would that be any good to me? it might be a little on the small side for the task.
                  gaskets only then.
                  I would recommend getting the right tool for the job. For saftey and speed purposes...
                    i'll try to find one to borrow. thanks for the help!
                    my oil pan was replaced and i used the one piece felpro rubber gasket - should i leave it intact as opposed to cutting it and replacing the ends with cork like the timing cover gasket set recommends?
                      leave the one piece gasket intact. F that cork nonsense.
                        good, good...i think i found a harmonic balancer puller. if the owner can't find it, i'll see if i can borrow the one from school for an evening
                          x1000!!!!!!!!!!!!
                            there won't be a cork gasket left on my engine when i'm done with this actually
                              Is the big guy a 15/16" bolt?
                                I believe so. If I remember corretly it was under an inch. If you have an impact gun, it would be a good time to use it!
