Three new codes....12, 21, and 34
    OK, a 34 popped up about a month ago, now I have a 12 and 21. The 21 is easy, that's the engine coolant temp sensor for the PCM. 12 is the IAC, which might be helped by cleaning, but maybe not. 34's the EGR, which again, might be helped by cleaning, but you also have to clean the intake passages as well. What do you all think?
    95 DGM Impala SS, 383, LT4 cnc heads, LT4 matched intake, Holley 58 mm t/body, GM 846 cam, GMPP 1.5 rr's, F-body MAF, BH OBD I PCM, LT4 knock module, K&N cold air, Edelbrock headers, Flowmaster exhaust, BBHP #73 6-speed, 4:10 gear, sloted and drilled rotors, Z28 cluster
    96 Buick Roadmaster Limited Wagon, mostly stock
    77 Ford F150, 400M auto, longbed
    98 Suburban LS 5.7L Vortec, stock
    90 Grand Marquis, stock
    that god damn code 34. pull the EGR and check. prolly more than likly, the potentiometer is gone. iv replaced somany on my bros car, that i eliminted the damn thing. since, if the ECM thinks its open, it will dump more fuel. when the EGR works, its good. its the fact that now, parts are shit now adays.
      how do you eliminate the egr or the evp sensor? ive wanted to get rid of my wifes on her 86 cp because hers always comes up with a code 31. I think a 31 is low signal to the evp.
      1984 mercury grand marquis ls rebuilt 306 flat top pistons with factory cfi and lincoln headers with single glasspack dual snorkle air cleaner. Gloss black paint with slick top coversion.
      1986 mercury grand marquis colony park 5.0 sefi dual exhuast thrush turbos with h pipe and turbines
        they have all you need, for EGR elimination. if you dont want to buy a blocker plate, you can make one too.
          thank you sir.
            You also get 21 if the engine isn't warmed up.
            31 is usually a bad sensor, but may be the metal plate inside the valve that the sensor contacts is bent or worn away. 34 may be a bad sensor, or a chunk of crap stuck under the valve pintle. Honestly if you can fix the egr system, you're better off. You get a CH of fuel economy out of it, and it does no harm to engine performance. The birds like it too.
