Header Leak
    I must admit I will have a hard time sleeping tonight after reading this thread....
    1991 Grand Marquis LS blog- Mayhem; two 12" Kenwood 800w subs, True dual catback, BBK shorties, cherrybombs, steel top, L/H hella lights, 18" AR Torq thrust, Trans cooler, class 3 hitch kit, more on the way...
      havnt had any issues with mine at all, but there are def differences in header design the bbks i have have a good flange surface. gasket and some red goop and it is good to go, the headers that came with my HO are oval port headers,and have been machine a bit, but even still i dont believ that these are very helpful as the ports are not going to match up in any form for perfromance wise. unless you port the heads to oval shape. i think they are hedman hedders but dont quote me. they may even be frpp but i dont know
        bbk 1515 headers, a good gasket, some red goop or copper and youll be fine, install tourqe down, warm engine up , cool down re tourqe. youll be fine mang
          Hmm, never retorque, no rtv, mr.gasket ultraseals on mine. No leaks. The BBK 1515 headers. I just tighten them up a bunch of times to start off with, with stainless steel allen head bolts, lock washers, and custom socket to be able to reach all the bolts.
            Tell me more!
              If you have to use RTV, then you're doing something wrong. The super cheap paper gaskets that come with headers are worthless, they may work for a little while but that's it. I always use stock replacement gaskets from Fel-Pro and NEVER have a problem...on all different brands of headers...copper isn't really worth a crap either...I've never torqued header bolts to any spec and I've never done them in any particular sequence and never had problems with stock replacement Fel-Pro gaskets...no monkey snot, no rtv and no magic spells.
              Good luck,
              Don
              '85 CV coupe- 351W, T5-Z, FAST Ez-Efi, shorty headers, 2.5" duals with knock off flowmasters, 2.5" Impala tails, seriously worked GT-40 irons, Comp 265DEH cam, 1.7rr's, Mallory HyFire 6A, Taylor ThunderVolt 50 10.4mm wires, 75mm t/b, 3G alt swap, 140mph PI speedo, PI rear sway bar, '00 PI booster/MC, 95-97 front spindles, '99 front hub bearings/brakes, '92-'94 front upper control arms/ball-joints, 3.73's with rebuilt traction-lok, '09 PI rear disc swap, '96 Mustang GT wheels with 235/55R17's.
                What he said. Shouldn't need magic goop or any crazy nonsense to seal and keep the headers sealed. I did try copper gaskets once and they leaked like crazy. FelPro works, but I've also had good luck with the MrGasket black Ultra Seal gaskets. I do tighten them starting in the center and working my way outward but I do that with most any gasket.
                  Well I contacted summit and they said to send them back, free of charge, and they will send me new ones. As soon as i get them out of the box i am checking them with a precision straight edge, and going to use the ultra seals! I'll take the straight edge to the heads as well to double check the surfaces. Hopefully i will have better luck round 2! The one header was pretty damn warped!
                  -Phil
                    I've been buying the cheapass mr. gasket gaskets. But since I popped another one I'm gonna be buying some better ones next time.
                    1989 Grand Marquis LS
                      Mac headers are the most fun of them all because they don't have a single flange...individual flanges for each tube, which is usually fine the first time...but take them off one car and try putting them on another is a royal pain...the official Mac header tool is a big ass prybar.
                      Good luck with the next set!
                      -Don
                        ugh, Mac headers. The only kind with individual flanges that actually fit right are the stock HO headers. Don't know why, but the damn things never seem to warp.
                          I used stainless steel allen head bolts. They take a 5/16" allen. I cut the elbow off of one of my allen wrenches and stuck it in a 1/4" drive socket. Can get to everything easily.
                            Where did you get your bolts from?
                            -Phil
                              if I had to guess, McMasterCarr
                                Just had to replace my passenger side header gasket yesterday....I used the felpro one's
                                The Best
