Variable Venturi Replacement.
    Anyone know if one is still made and a part number for it. Help would be much appreciated.
    1989 Grand Marquis LS
    nope, was discontinued. only hope is to find a used one or replace with a 2150motocraft carb. i tried to get another for my car, but wasent able to.
      Figures. My dads capri needs a new carb and I know the VV replacements fit the 2bbl intake. Dont wanna make custom linkages for the aod kickdown.
        Re: Variable Venturi Replacement.
        Holley carries a reman VV carb. It is listed under reman carbs on the Holley site. You can buy them through Summit. You do not want to put a VV carb in place of a conventional carb though.
        Waht does your Dad's Capri have for a carb now?
          Wore the fuck out 2150 2 bbl with the aod linkage thing on the side. Have to spray carb cleaner down it to start it cold. Only gets 15 mpg with it.
            Put another 2150 on it. You don't want to dick around with a VV, especially on a car that never had one.
              Im not dicking around with one. I thought the replacement vv from holley or edelbrock were 2 bbl's. Thats why I asked about it. Its hard to find a good 2150 with the linkage around here. And my dad dont wanna spend 200 bux on reman.
