Originally posted by MattDoscher
View Post
engine hesitation
Initially I tried adjusting my old TPS. I took a voltage reading from the green wire on the TPS connector and got 1.4V. After attempting to enlarge the mounting holes on the TPS and eventually cracking one of the holes, I was only able to achieve 1.2V. I bought a new TPS from Ford and still have a high Voltage reading. I am not able to adjust my current TPS to .98-.99 volts. I heard on another forum that I should not touch the idle speed screw. Is this wrong? SHould I try and adjust the idle speed screw? I can see how that would change the position of the throttle plate thereby lowering my voltage reading for the TPS. But would the ECU learn the reduced idle speed if I turn that screw?
Originally posted by MattDoscher View PostInitially I tried adjusting my old TPS. I took a voltage reading from the green wire on the TPS connector and got 1.4V. After attempting to enlarge the mounting holes on the TPS and eventually cracking one of the holes, I was only able to achieve 1.2V. I bought a new TPS from Ford and still have a high Voltage reading. I am not able to adjust my current TPS to .98-.99 volts. I heard on another forum that I should not touch the idle speed screw. Is this wrong? SHould I try and adjust the idle speed screw? I can see how that would change the position of the throttle plate thereby lowering my voltage reading for the TPS. But would the ECU learn the reduced idle speed if I turn that screw?
The jerking/hesitation is most noticeable while maintaining speed anywhere btwn 35 to 45 MPH.
As for TPS, I'm going to odd man out again and say this magic .99v threshold is a waste of time on a stock lopo. Why? The computer learns what the tps reading is at idle, and it learns what the tps reading is at WOT and bases its response accordingly.
Alex.
You're not supposed to adjust the screw. that said, if someone in the past has messed with it, the voltage will be a little high. Normally it comes out in the 0.9-1.0 range, but not always. As long as you don't get codes about the TPS being out of range, its fine though. 1.2 should be OK, but I think 1.4 is out of range. It zeros itself like Alex said, though it does have a range that it considers normal. Outside of that range it will assume the sensor is at fault and just ignore it.
One way to maybe determine if someone has jacked with the screw is to try unplugging the IAC. The idle should drop a fair bit, or cause the engine to stall. If the idle remains high, the screw may have been screwed with. Target idle on these is 650-700 rpm, and with no IAC its generally around 500 rpm. Its somewhat common for people to see that screw and crank it in when the car has some sort of idle related problem in an attempt to fix it.86 Lincoln Town Car (Galactica).
Well i checked timing today and its dead on at 10* and i replaced the tps just for the heck of it so we will see what happens now. Ive got a 25 mile drive in about 2 hours so i will know then. Also it seems i was wrong about the idle screw just what i had read somewhere. Theres alot of conflicting ideas on alot of this stuff my car will die almost immediately after the iac is unplugged and ive never touched that screw.Last edited by mercurygm88; 01-08-2012, 04:41 PM.
Thanks Alex. I will try driving it around like you said. If the hesitation is still there in OD and not there in D what would cause this? Thanks gadget73, what you are explaining makes sense in that the throttle stop screw shouldn't be messed with. I will try unplugging the IAC too. Mercurygm88, how did your drive go tonight? Do you still have problems?
Since the AOD has no external input, its only point of reference to shift in or out of OD is the speed your going, and the load that is on it. The speed range that the AOD typically pops into overdrive happens to be between 35 and 45 mph. If you live in Canada, that just happens to be the speed on a lot of our roads, so we get to experience alot of the OD shuffle. Anyway, if there are any slight grade changes, any slight throttle changes, the aod senses this (ie: tv pressure) and reacts according to that. Unfortuantely, the AOD can't see into the future and know that you are only on a very slightly undulating road, following somebody, which doesn't need a gear change in the grand scheme of things, but becuase you are at that special speed, it keeps trying to shift into a gear for the NOW, not the OVERALL, so it ends up doing the OD-D shuffle, and depending on the road that can become a very erratic experience.
If this is your first AOD, or you come from a general motors background, the AOD wants lots of throttle input to do something. This can appear to be a hesitation, if your feather footing it. If you come from a GM background, this is an even more pronounced effect. You will get used to it. Eventually.
Alex.
I've had Fords my entire life and when I first bought my '87 GM I thought the trany was defective. Still have it and still have to explain to passengers we WILL get to where we are going and NO the car is NOT breaking down!!
Originally posted by MattDoscher View PostThanks Alex. I will try driving it around like you said. If the hesitation is still there in OD and not there in D what would cause this? Thanks gadget73, what you are explaining makes sense in that the throttle stop screw shouldn't be messed with. I will try unplugging the IAC too. Mercurygm88, how did your drive go tonight? Do you still have problems?
mercurygm88; sorry to hear you still have the miss going on. Have you tried what gadget73 recommended by unplugging your EGR regulator and tried unplugging your IAC? What did you find out by doing this? Have you tried driving in D and not OD at speed yet? Just curious if you have tried these things and what you found out. I have yet to try these recommendations because the car is w/ my mom in SC and I live in VA, but I am looking forward to doing it to see what I discover. Alex; I'm still not convinced that it's the D/OD shuffle. Not to say your wrong or anything it just seems to me that my AOD shifts fine. It shifts into OD right at 40MPH under normal acceleration and 50-55MPH under harder acceleration. Upshifts and downshifts seem to be fine. Like I said in my first post the car sits alot and doesn't get driven unless I'm home visiting in SC. It seems to me this problem I have is engine related, specifically fuel delivery or emissions. Could be carbon build-up or some stale gas deposits. I keep STA-BIL in it to try and keep the gas fresh when I'm not there to drive it. The sputtering/hesitation will only occur under light throttle to maintain speed either before the OD shift or once in OD at 45-50MPH. If I give it slightly more throttle it goes away, the AOD does not try to downshift into D when doing this unless you apply more throttle pressure say to pass another driver. Then it will downshift into D.
Matt
