What is good compression for stock low milage engine? 175psi?
Whats is a good compression for stock 5.0
“Cars are the only thing on earth that will beat you, break you, make you bleed, make you cry, spend all your money, spend all your time, not work and not care that you will love more, the more they abuse you.” -AnonymousTags: None
North of 125psi is generally considered acceptable, 150 or better is good. 175+ and its plenty healthy.86 Lincoln Town Car (Galactica).
