lopo cam specs vs ho?
    Does anybody knows if lopo cam has the same duration and lsa as a ho cam (I know that ho has higher lift)
    “Cars are the only thing on earth that will beat you, break you, make you bleed, make you cry, spend all your money, spend all your time, not work and not care that you will love more, the more they abuse you.” -Anonymous
    No. Ho has more duration, by at least 5 degrees at 0.050
      HO is something like 210/210 @ .050 and .440/.440 lift though I think '88. '89-up added a little duration to either the intake or the exhaust.
      Lowpo specs seem to be pretty hard to come by, since all the ones I've seen seem to be for a lowpo flat cam, when the cam in question is usually a lowpo roller. If I were really ambitious I'd stick my old lowpo roller in a block and measure it ....
      Advertised specs for replacement lowpo flat cams seem to usually be in the 190 @.050 range. Bit less lift too. Consider that it's intended to be run in a small engine AND run super-smooth even with lots of intake and exhaust restrictions AND make peak horsepower at something like 3500rpm ....
      Wait, I'm an idiot typing all that. Have a search for my thread on SpeedPro replacement cam specs and part numbers.
        Does anyone know what the power band range (rpm) is for a 1989 HO cam in a 91 GM AOD w/2.73?
        It seems to really start pulling at 25 mph up to about 65 mph.
          2500-5200 rpm IIRC for the HO cam in stock HO engine.
          as for speeds... that moment you feel the sudden rush in acceleration... that's about 2500RPM... If you're holding first... then yeah... 55-60mph would probably be your shift point so the trans would actually kick into 2nd a little under 65. Without a tach though, there's no real good way to know.
            the 5.0L "Base Engine" camshaft (E5ZE-AA, F1AE-AA) has the following specifications.
            .379
            .395
            244
            256
            Read here for the original thread; http://www.crownvic.net/ubbthreads/u...9566#Post29566
              Ford CV/GM is 244/256 gross duration and .378/.395 lift
              Mustang HO Ford cam is 266/266 gross duration and .445/.445 Lift
              Explorer and truck 5.0/5.8 is 256/266 duration and .396/.448 lift
              Lightning Flat Tappet Melling is SYB-30 197/209 @ .050 duration and .416/.443 lift
              5.8 HO Truck flat tappet cam is Melling SYB-35 206/221 @ .050 and .445/.453 lift
                Found the specs for the lopo cam: http://forums.corral.net/forums/5-0-...-5-0l-cam.html
                  Originally posted by 90ltd View Post
                  guess you never bothered to read my response when you first posted this?
                  From post #6 --- the 5.0L "Base Engine" camshaft (E5ZE-AA, F1AE-AA) has the following specifications.
                  .379
                  .395
                  244
                  256
                    Man were talking about same thing. Its just the numbest you listed represent actual valve lift. And the numbers posted in the link show true cam lift.
