My '85 MGMCP loses coolant.
There's no temp gauge, but the radiator temp feels normal after driving.
Tonight I started it cold and idled it up to temp. The cabin heat came on after about 3 minutes. The top radiator hose stayed cold for about 5 minutes, then warmed up rapidly. So I think the thermostat opened normally. Everything seems normal so far. TOO normal. There's no leak after ten minutes of idling.
Then I revved the engine and bingo, a trickle of water. OK. Stopped the motor and took a look. The lower half of the seal around the water pump is wet. I didn't see water at the t-stat seal or either hose at the t-stat. If the leak was from the t-stat area, there'd be liquid at the top half of the water pump seal also, wouldn't there be?
<begin stupid newbie questions>
The car needs a new water pump and gasket, right?
What else would you do at the same time? I'm thinking hoses, t-stat and t-stat gasket? And the alternator belt is made entirely of cracks, omg.
The shop manual devotes less than half a page to water pump replacement. What's the best guide for a newbie? My coworker said get a Chilton's. What do you all use?
How do you decide when to try a repair yourself and when to take it to a mechanic? On the one hand, I know an honest, friendly, professional shop. They fix every problem I've ever brought them. Good rates too. On the other hand I am a wannabe mechanic. I want to do more in life than change the oil.
