coolant leak
coolant leak
WARNING: Above advise is based on actual experience or just plain common sense. In the event said advise is determined to be incorrect you are entitled to a full refund of exactly what you paid for it.lol
85 LTD Crown Vic Coupe 302 CFI Dual Exhaust No Cats Thrush Welds
pwr windows, locks, seat, antenna
cruise, tilt, white on white, maroon interiorTags: None
Originally posted by 86VickyLX View PostIntake gasket. Timing cover gasket, water pump gasket.
If you have access to a coolant system pressure tester, hook it up, put it under pressure, see where it comes out.
Honestly I would replace all of those gaskets. It wouldn't hurt to pressure test it anyway but I would replace them all at the same time...the same stuff has to come off to do either the water pump or timing cover gaskets, and the intake gaskets are NOT far away.sigpic
I hate to second-guess, but this is from personal experience with a leak that pooled in the same spot:
Why are you 100% sure it's not the t-stat? I spent a good week (actually, a very shitty week) trying to re-seal the warped and corroded t-stat housing. A half dozen paper gaskets, two different liquid gasket types, different cure times, false starts that varied from incredibly slow leaks to full-throttle only leaks to leaks that didn't manifest until the car was sitting cooling at a friend's place after a 30 minute drive. If the leak is a pinhole at the bottom of the t-stat housing I found you could even run your hand over the offending area without getting it wet.
Just food for thought.
Originally posted by johnunit View PostI hate to second-guess, but this is from personal experience with a leak that pooled in the same spot:
I can't find any leaks at the T-stat on mine. I haven't opened the front cover yet so the source of the same leak pooling remains unknown.
Thanks for the idea though, I had ruled it out because it was recently replaced along with the hoses, tstat, water pump but I never did the timing cover gasket.sigpic
intake manifold gasket mostlikely
weep hole behind the water pump is just below that bolt directly over the coolant in the first picture. that's where my Mark was leaking. probably needs water pump seals or new water pump.
Originally posted by 1990LTD View PostI can't find any leaks at the T-stat on mine. I haven't opened the front cover yet so the source of the same leak pooling remains unknown.
Also, check your clamps, just because they're new doesn't mean shit. Some come loose and will cause hoses to leak, and potentially blow off of the neck. BTDT
i check hose clamp tightness like every other oil change
*though* the top of the timing cover? How weird.
Will need to pop that off and repair it - either find a replacement in your price range, or find someone competent in brazing or welding aluminum. A shop across town from me will weld up anything starting at $25; I had them fix a cracked aluminum oilpan once.2012 Mazda5 Touring | Finally working on the LTD again!
if you mean the little hole in the top of the timing cover that is directly behind the water pump... it's a weep hole.
Here's a pic of the one on my Mark's engine since it's actually semi clean in there...
The blue circle is around the weep hole.
The red arrow points to the front of the car.
the green arrow points to the water pump.
what's the hole there for? maybe that's where mine is leaking from...it's not wet anywhere elsesigpic
Originally posted by slymer View Postif you mean the little hole in the top of the timing cover that is directly behind the water pump... it's a weep hole.
