new car checklist
    new car checklist
    heres the list of stuff i plan on doing as soon as i possibly can to the new vic after i ascertain its true condition. alot of this may seem overkill but hey, i am erring on the side of caution
    pcv valve, grommet and screen
    adjust the tps
    check the timing
    replace the iac(shifty had a brand new one and pete sent me one)
    plugs
    plug wires
    cap
    rotor
    new starter(shifty's is brand spanking new so why not)
    new regulator(shifty's was brand new)
    check the tv pressure and replace grommet with brass one if it odesn't already have it(if it hasn't got the grommet, i'll take it off of shifty)
    oil change(i got a box of 20 or so fl-1as i put on layaway at work just before they went on clearance )
    new headlight switch(shifty has a new one)
    air filter
    fuel filter
    trans filter change with new fluid
    lube up the front end
    grease all the hinges
    get some of that graphite stuff in the keyholes
    now for the "non-essentials"
    replace the lights up front with a set of new rectangular fogs
    clean the interior real nice
    get some black carpeted floor mats with the blue oval
    pull off of shifty the engine compartment braces, along with the undercarriage braces
    install teh pi cluster
    install shiftys cd deck and the speakers
    if the front swaybar is bigger on shifty than the new one, pull that obviously
    nothing in that particular order either lol. any other suggestions ofr the essentials?
    Save a seal, club a liberal.
    Yeah, I got a suggestion.
    Go pick up the car!
      TV bushing should be first. Should bring one when you pick up the car
        sunday, mang, sunday
        i gotsa wok all the rest of this week :cuss:
          Originally posted by mrltd
          YOU FORGOT THE FIRST AND MOST IMPORTANT!!!
          TV BUSHING
          no i didn't
          grommet, bushing, same thing
            I saw that after I posted and changed it...Im sleepy...
              thats alright
                belts and hoses............esp the heater hose that comes off the lower intake
                  i forgot about belts
                  thanks for reminding me lol
                    Re: new car checklist
                    Do they make fog lights that fit in the stock headlight spot?
                    2000 Grand Marquis LS
                    Mercury Owners Group member
                      nope, these were the lights i was referring to
                      it looks like those might be old cop lights. if they indeed are they be coming off asap
                      these are the fogs i was thinking of getting
                      the lens even matches the color of the car
                        Darn, that would be nice, fogs in a factory location.
                          my 84 had driving ligths installed that looked like they were a factory item. the mount is welded to the bumper :geek2:
                            Gotta find some to fit where the headlights are. Put high-low in one spot and fogs in the other :slug:
                              Put those lights in the same place mine are. They are almost the same size as mine too.
