Takes Ice Ages For It To Turn Over
    No, your car is carbed and that's just the way carbs are when they're not 100%. No need to plug in a properly set up carb at 24*F much less 0*F, my car gave me no trouble last winter with the carb at all. It sounds like the choke and possibly high idle isn't quite set right, but everything else is. Lucky for you, choke and high idle are 2 of the simpler for the uninitiated to set up.
    1992 CVLX. 5.0 HO/GT40P/T5/3.73/trak-lok with bolt ons. 02 front CVPI setup, rear HPP setup, CVPI shocks around, F250 radiator, e-fans, and the power of 3G. 15.92@89mph, 2.4 60', 4700' elevation (5500' DA) with 3.08 open rear and the old oil chugging 289. RIP.
      its a carburator. They start differently than fuel injection. You have to pump the throttle once or twice and let it warm up a little before it will run. Its just how things used to be. If the carb and associated parts work right, it'll fire and run fine below freezing but it may take a little more work.
        Alright, I'll have the choke/cabeurator/throttle adjusted and the high cam idle thinger investimigated.
        Thank you.
