Fuel System Stalling/Hesitating/WTF?
    Okay, so today after coming back from a 2 hour drive or so on a hot day, I found the engine stalling/spluttering/I dunno what was going on at about 50KPH.
    It was acting like there was intermittent fuel in the system as though I was about to run out of gas, only I'm not of course.
    This happened once before, when I found the air filter was dirty as can be. Only the engine would do this at about 20KPH instead of 50KPH and it would actually stall out on me.
    Putting it in Neutral and revving the engine produced black smoke from the exhaust.
    Can anyone help me pseudo-diagnose the problem? I suspect fuel pump/carbeurator?
    How old is the fuel filter?
      2nd that. Found my fuel filter had 65,000 miles and god knows how many years on it when I asked a similar question about lugging on the highway, uphill @>60mph.
      Might not be so simple, but, it's a $5 start and not a bad thing if you have no idea when it was last done.
      Btw, fram seems to have a bad reputation. I haven't examined various filters personally, but too many individuals are crying foul for it to be random slander-- so maybe pay $8 for a more premium non-fram fuel filter.
      ....though... I'm not sure that a clogged fuel filter would lead to black smoke....if anything the car should be running lean and not getting enough fuel? black smoke =oil or too much fuel.
        Have you changed the spark plugs because it can be that the fuel that is not burning burns after and produce black smoke. ONe thing it can be bad for the catalytic converter. Also oil produces blue smoke. Black smoke means running too rich. try the fuel filter and try the plugs and wire. Basically try doing a tuneup.
        1992 Mercury Grand Marquis.
        Upgrades: Big Brake Upgrade, digital dash, Custom ignition Switch system, sequential tail lights, Teflon Fuel lines, LED interior lights, rear end rebuild with limited slip.
        Future upgrades: 5.0 swap, 4r70w swap, aluminum driveshaft.
          The plugs and wires were changed out a week ago.
          I suppose it could be the fuel filter, but why the black smoke?
            black smoke is excess, unburnt fuel. blue smoke is oil... white smoke is coolant/water (IIRC)
            Bad plugs will leave a lot of unburnt fuel since the spark sucks. Also, injectors that are cloggy will not atomize well and give shit for burn too. Carbs that dump too much fuel will do the same thing.
              slightly too much fuel shows up grey, but it will burn your eyes and nose. Vacuum leaks will make the carb do stupid things too. You won't get proper airflow across the venturies and the fuel may not atomize properly. Or there could be something wrong in the carb that makes it just dump fuel down the throat. I've seen sticky floats or leaky needle seats cause this problem.
                So if I replace the fuel filter and carbeurator I should have this problem eliminated then, correct?
                  replacing the carburetor would be a bit drastic at this point. It'll run you 200+ for a rebuilt carb.
                  This is a stock variable venturi carb, right? If so, your fuel filter is on the carb, right where the fuel line goes in on the front. It generally won't go "bad" in a way that messes up the operation of the car like a fuel injected car's filter will, though it's still a good idea to replace it.
                    Okay, so...
                    The symptoms I'm describing...is that indicative of a faulty fuel filter? Or is the carbeurator damaged?
                    I'm asking so I can budget for necessary repairs (today).
                    Thanks for the replies, by the way.
                      How do your spark plugs look? For the longest time I had one of my carbs calibrated too lean and was trying to make up forthe off-idle stumble with an excessively rich idle. Funny thing, the plugs kept getting all black and fouled and then it'd idle even weirder. Constantly stunk like stink too, of course.
                      What's the condition of the rest of the fuel and ignition systems?
                        I had a similar problem on a 1987 ford crown vic. It turned out to be dirty injectors. I took it to a shop, the mechanic hooked it up to a "cleaner". He said it took about 45 minutes IIRC to clean the injectors. After that WOW. Big difference. I don't remember the machine name, but it hooks into your fuel rail IIRC and just blows/dissolves/cleans the dirt out of the injectors
                        -1973 Volkswagen Bus Westy
                        -1986 Honda Magna 700cc
                        -2011 Subaru Outback
                          I had new plugs put in just over a week ago, so I imagine they more or less look the exact same way they did when I bought them.
                          And I doubt it's my fuel injectors.
                            If it's not the fuel filter or carbeurator, I suspect it's the fuel pump.
                            Worst case scenario, I replace:
                            - carbeurator
                            - fuel lines
                            - fuel pump
                            - fuel filter
                            - gas tank
                              Check your vacuum lines. I had a similar problem with my '86 CV (of course mine is EFI and still running MAP) and it turned out the line was cracked going into the MAP sensor. It would run like crap and spew black smoke. But in any event, vacuum lines will make these cars run like crap.
