some small amount of water pump play OK?
    When I grip the pulley and twist it gently, I can feel it ticking side to side. So there is some small amount of play.
    Perfectly normal, or should there truly be NO play in the bearings?
    it won't have zero play. If its not leaking and not making noise, let it be.
      cool. Will do so.
        Pretty much. Though at least AutoZone has (or did have) a replacement as cheap as $15. I got that one when one of mine was wobbling horribly, and it seems fine.
