Holley TBI Unit
    Holley TBI Unit
    This is the unit i am thinking about replacing my CFI with.. Give me some feed back on this and any other good idea's. Im tryin not to go all the way MPFI b/c of all the shit i would have to change. So just check it out for me and give me a lil help on this one. If you find something better post it on here for me to check out.
    The Best
    Aside from the 275hp limit it seems pretty good. 275hp is not shabby at all though.
      How much would it cost you? Can you put bigger injectors in your current cfi, say from a 351 application? And what about GM TBI's I bet your could find a used one cheap for a 350 from the early 90's, if the bolt pattern is right.
      -Matt
        bigger injectors wont work on a cfi and i dont think the oem gm's tbi would work gotta go universal holley
        The Best
          How much does teh pro-jection system cost?
          It looks secksy
            it's around 800 bucks jon.......nice thing about it is it can be tuned inside the car with a laptop computer..........they make a 4 injector setup also......but it's more $$
              I will probaly just go with the 2 barrel 4 is nice but i got alot to buy so im tryin to spread all teh money around
              The Best
                I've seen Holley MPFI systems that had a progressive quad throttle body setup. Pretty badass stuff.
                  no 351 came with cfi only the VV carb and EFI
                    Nate, run that and you will be my hero!!! I already want it.
                      I've installed this system on 2 different cars. It is NOT tuneable with a laptop. It has 5 adjustment knobs on the ECM and that is all.
                      The 4-barrel Holley Commander system is laptop adjustable.
                      kevin
                      FOR SALE: 89 Grand Marquis GS HO. Quarter mile = 15.8 @ 87mph -- pics http://public.fotki.com/vfr700f2/car...rcycl/mercury/
                      Junkyard HO, MSD wires, stock Mustang headers, off-road H, Hemi Super Turbos. 3.55 trac loc, HO governor and servo in stock rebuilt AOD. 3-row rad, air pump delete, cop rear bar, wagon rear springs, 93 CV rear discs, 98-02 Grand Marquis wheels, Class 3 hitch, aluminum space-saver spare.
                      Coming soon: 98-02 front brakes, cop springs, Monroe cop shocks, 96 Cobra wheels w/255/50/17. Better yet, need a nice wagon to put all that stuff in.
                        Whats kind of response did you get from installing that type of TBI. How good did it work and how difficult was the hook up.. Also was it problem free or problematic? Was it installed on a CV GM TC?
                        The Best
                          Why not just run a regular 4bbl carb and aluminum intake. Should make good power and be economical depending on the type of carb you get.
                          Tom
                            It wasn't on my cars. I worked at the shops that sold the systems. One was an ex-diesel ~81 Olds Cutlass with a ~69 Olds 350. Driveability was very good with the carb, so no big gains there. Performance improved slightly, MPG decreased slightly. The other was an ex-turbo 81 Trans Am with a 455. We put the EFI on it ~10 years ago and the car probably still isn't on the road.
                            Install wasn't tough. Drill a big hole in the firewall for the wiring, find a place to stick the ECM, mount an inline fuel pump, bolt on the system.
