1990 Town Car Header Pics - Performance Question
    Just got back from the junkyard, and I found a 1990 Town Car with the tubular-style exhaust.
    Since I had never seen them in person, or in any picture, here y'go!
    Now, having seen one, while they are tubular (made from tubing), they certainly are NOT "headers". They utilize a common "log" design, as opposed to four individual tubes which mate to a collector.
    The design doesn't in any way scream "performance" over the standard cast-iron design.
    Does anybody actually have a set of these bolted up - and if so, what performance change did you experience? Based on their design, I wouldn't experience a benefit that is comparable to a Stock Mustang manifold. But, I realize that looks can be deceiving . . . !
    So - does anybody have any experience with both - this style, and a "true" Mustang stock header?
    HO with Explorer Cam, Electric Fan, Cop Sway Bars, Dual exhaust with no mufflers, 15x7" American Racing; 215/70R15's front, 255/60R15's rear, 3.55's with Trak-Lok.
    I dont, but where are you located??? send me the fan shround/coolany bottle off that thing in the junkyard
      I'm in Nebraska - home of the football team that "used to be".
      I'm willing to help folks out - if seriously interested. The yard where these pictures were taken isn't cheap - but I could get prices if interested.
        they might not flow much better than the manifolds but they would cut about 40 lbs. off the front of the car.
          That's a point that I did not consider!
          Anybody got a guess on what a set should be worth.
          The yard wanted $75, which seems too high.
            Too damn high, maybe $40 if I was feeling generous at the time.
              $75 for those is nuts. I'll agree with Blaze, maybe $20 each tops. The yard I go to charges $15 each for exhaust manifolds. The flow is probably marginally better than iron, but the weight savings is a definite plus. Those iron manifolds are heavy suckers.
                forget that yard!
                Scott helped me pull mine (not installed yet) from a yard that wanted $15 each.
                Scratch the shroud, lol
                  sounds like the yards around here If I would have known anyone was interested in those I would have snagged them off the 90 towncar I got my engine from.
