dropping oil pan/ removing pump? (just a couple questions)
    As suspect #1 in my low oil pressure, I just need to stop guessing and pull the old pump and see what's what.
    I did this once before, had it on a lift, removed the front two motor mount bolts, jacked the engine up a few inches, dropped the pan a few inches, gave me the access I needed to R&R the pump.
    At the time the upper intake was not on.
    I know there's not whole lotta room between the intake and the firewall;
    I just want to double check, when I do this again, do I need to mess with the top of the engine at all? Remove any tv cables, pull any upper intakes, or will the engine crank/angle up just fine without anything bumping into anything else?
    I don't need to jack the transmission, correct? It can just angle on its mount?
    thanks!
    And, how long did this take you?
    I remember it taking 2 hours, but without a lift, it might take me longer.
    Maybe I can convince a friend at a shop to accept 2 hours labor to do it for me; book value is 5.8 hrs though and I just don't have that kind of money.
    thanks!
    Pull the upper intake as a unit. That means, leave the egr and throttle body attached. unbolt the throttle linkages and tv cable. If you don't damage the plenum gasket, you can reuse it. I've done it in the past and have not had any problems. Unbolt fan and fan shroud. If you're not removing the pan from under the engine, then the radiator can stay in. Remove hood. Jack car up a decent amount, put jackstands under it. Get it as high as you safely can. You're gonna be under there, and you're gonna want to get as much room as you can. unbolt motor mount bolts. Hoist up engine as high as you can without lifting the car. I had to jack up on pan of trans (with a block of wood between jack and trans) to get as much space as possible.
    Make sure you put the gaskets in between the pump and block, and between the pump and screen.
      why unbolt the fan and fan shroud?
      why remove the hood (just raising it isn't enough?)
      I was just trying to refigure that out the other day: the tv cable and throttle linkages, they just pop off if I pry with a bit of force, right?
        Because you'll hit the shroud with the fan and potentially break something.
        What are you planning on lifting the engine with? I used a tree, a cherry picker will need room to lift the engine also.
        Tv cable, you're is a 90 right? There should be a bobby pin like thing you undo, then the cable comes down, remove the bushing, and keep them somewhere you won't lose them.
        The throttle cable unclips. Prying straight down should release it.
        2 10mm bolts in the back remove the bracket from the EGR spacer.
          ah, got it. I was going to put a jack under the harmonic balancer to prop it up that way-- which would mean not having to lift the hood, though, removing the hood is only 15 minutes anyway. No big deal one way or the other.
          Shoulda thought about the fan. When I redid my pump (and I'm still hoping, badly), the fan wasn't in yet-- so that didn't come up!
            Let me ask you a question, did you lift the engine from the harmonic balancer the last time you did this?
              :jawdrop:
                That is a very good question.
                  yeah, really not a good idea to support the engine from the balancer. Bad for the balancer for one thing, but the crankshaft and the bearings were not intended to support the weight of the motor. You could possibly bend the crank or damage the bearing.
                    I was going to put a jack under the harmonic balancer to prop it up that way-- !
                    What. That is not, in anyway, shape or form, any type of lifting point.
                      just take out the wiper motor,fan and you should have enough room to raise motor.put lift under trans bell housing and lift as high as you can and get some 4x4 blocks to use under motor mounts to rest on thats all i did
                        Might just use an engine support bar for the next go around, that way I can put it up on the lift. Cheaper than an engine crane too; harbor freight has one for $60 now.
                        Actually, I've never used a support bar, does it end up resting on the body work on either side, and would it start to crush the sheet metal to lift the engine that way?
                        Yes, I did lift it by the balancer the last time-- and under the direct supervision of a mechanic/instructor I'll add, he told me that the balancer was fine.... *sigh*
                        I guess I won't do it again-- are the chances of having already damaged anything very high?
                          Yes if you left it supported by that.
                            just the engine, not the car.
                            Any way to know?
                              Pull the engine apart and measure the crank. Like Gadget said, it's not designed to handle that much weight.
