I want to put one in my Towncar. What is involved? Thanks yall and happy :3gears:
how do you install a tachometer?
Originally posted by Grand_Marquis_GTOriginally posted by phayzer5How to install: Hook wire to the tach output of your MSD box :banana:
although i had some problem finding it through the mess of wires to run a MSD.... all 5 of themhttp://secondhandracing.com/Home.aspx
hey i just installed a Temperature Gauge by Sunpro. It says im running around (cruising)-175 and 190-(at a stoplight) degrees most of the time. Is that the normal operating temp? I have a 190 Degrees Thermostat.1989 Lincoln Town Car - "Anabelle" - Original block, .030 over with SpeedPro pistons, rods fitted with ARP hardware, FRPP +volume oil pump, GT-40 3bar heads, Crane 1.72 rockers, 89' Fox cam, 93' Cobra lower intake, Explorer upper and 65mm TB, 93' Lightning EGR spacer, K&N intake kit from a 4.0L Ranger, 19lb/hr injectors w/ 87 Mark VII ECM, cat/smog deletes, Big Brake conversion, 3.55 K-Code Trac-Lok/Disc brake rear axle, CVPI LCA's w/1" sway bar in rear, wagon front sway bar, BBK 2.5" off-road H-Pipe, Flowmaster super 40s, HPP wheels, 3G alternator w/LMR.com wiring kit, gear reduction starter conversion, Best 1/4 time: 16.0 @ 85mph.
Normal. As long as its under 210 you're fine. 210 won't hurt anything either but its a sign to turn off the AC and let the motor cool off some.86 Lincoln Town Car (Galactica).
