what about motorcraft 2150s(based holley) for example. pretty darn simple. i havent had much issues with them.
Carburated cars and weather.
After surfing the web about carburators I think i found the most reliable ones: autolite 2100 2v and 4100 4v.
Any pros/cons about them?“Cars are the only thing on earth that will beat you, break you, make you bleed, make you cry, spend all your money, spend all your time, not work and not care that you will love more, the more they abuse you.” -Anonymous
Huge cons: No aftermarket support, not produced new. Other than that, I'm sure they're perfectly fine.
'83-'85 Mustangs came with Holley 4180s, SFAIK.
What would your goals be for your carburetor?2012 Mazda5 Touring | Finally working on the LTD again!
2100 and 4100 are some of the best Carbs I have ever dealt with .
This place specializes in them
1988 Signature Series Town Car
2100/2150s are the simplest automotive carb i think, and are super reliable. also, you can still get the carb kits for about 30bucks.
really? im sure even ray charles and stevie wonder could rebuild one
Originally posted by 1987cp View PostHuge cons: No aftermarket support, not produced new. Other than that, I'm sure they're perfectly fine.
What would your goals be for your carburetor?“Cars are the only thing on earth that will beat you, break you, make you bleed, make you cry, spend all your money, spend all your time, not work and not care that you will love more, the more they abuse you.” -Anonymous
I happen to have a holley 4180 sitting at home. It's just a 4160 with the idle adjustment in the baseplate and blocked off, though you can kinda gouge out the blockage and regain adjustment. I don't think it's good for anything other than a "correct" mustang resto. Unless you're anal like my and want to retain ford-style vapor cannister function and 1985 parts numbers on a car that never could have come with a holley 4-barrel.
I love running a carb. No sensors or computer crap to worry about, easy to tune, and has been very reliable.
NA-15.78@91.21, 80hp shot-14.48@96.21
Im sorry if i missed it but what carb are you running?
Paul.Last edited by 90ltd; 05-31-2011, 10:23 PM.“Cars are the only thing on earth that will beat you, break you, make you bleed, make you cry, spend all your money, spend all your time, not work and not care that you will love more, the more they abuse you.” -Anonymous
Originally posted by marquisman View Postreally? im sure even ray charles and stevie wonder could rebuild one86 Lincoln Town Car (Galactica).
Ok today I bought autolite 2100 with manual choke with a code: C5 TF Z . What does that code means?“Cars are the only thing on earth that will beat you, break you, make you bleed, make you cry, spend all your money, spend all your time, not work and not care that you will love more, the more they abuse you.” -Anonymous
C5 means C(60s) 5 (5ths year) so designed for model year 65. I don't know what the rest means, but yeah, it's from 1965 or newer.
