car misses
    car misses
    got miss sounds like marbles under the hood apon acceleration and only when car is warm what would cause this
    Marbles? Sounds like a ping, sounds like timing might be a tad too advanced...
      running lean. what exactly is done to this motor ?
        explorer cam, intake, e7 heads
          ECM? Injectors? if you are running the stock lopo stuff that's why.
            ds9,19lb inj,explorer cam,explorer upper,lower intake, e7 heads
              Check for vacuum leaks first, also verify your timing is right.
                Is EGR enabled? If EGR is opening too early or too much, it will introduce inert gases into the mixture and make it too lean.
