255 V8 in a box??
    needs a short crank, super high flow heads, short cam, reinforced mains... set it up to rev to 9K... then it'll be fun
      I had a 255 in my 82 MGM 2 dr. 212,000 miles on the original motor. It ran good and got decent mileage. 18-22 mpg. VV carb was my only problem. Mostly highway miles. Under powered. When I ordered the car I should have got the 302. Sadly, the car has passed away.
        There was actually a guy selling 255 cranks on Corral for a ton of money, claiming they were some kind of gold. Aside from being a destroke crank, they were made in the early '80s so i wouldn't expect them to be some great material. Honestly i don't know but sounds like horseshit but if you wanted to build a crazy high-revving destroked motor maybe that's the ticket. Put it in a Dart block with 4.125 bore and have a 10,000rpm solid-roller screamer. Or just build a normal motor like the rest of us, lol. The 255 lived and died in a 2-year span for a reason i reckon. Enough said.
          The 3.8 V-6 replaced the 255 V-8. No need to have 3 small block V-8s then.
            302 CAN BE built to turn 10,000 rpm. one issue with the 255 bore is too small to run heads with bigger valves. Ran into this building 260 back in the day if i remember right the 255 has a smaller bore than the 260s did. havent thought about it since 79 when i got the cobra mustang
              no replacement for displacement... imo anyway.. i know others disagree. im fine with a torque monster that redlines and 5k lol
              Charlette - Brown 1977 Ford LTD - 351 Windsor 155K, Full Custom Pioneer system, green HID, interior & underbody
                Speaking hypothetically here, would a SEFI intake bolt onto the 255?
                Assuming Mass Air, would such a setup make for a usable engine, if a bit underpowered?
                | Junkyards
                  I think the 255 and 302 are identical except for the cylinder bore... so the intake should bolt on... someone may correct me.
                    IT might bolt on but would be a lot wiser to go with a 302 SEFI ECM and all the wiring than convert a 255 and need a different tune etc. Then there is fuel pump etc to complete it.
                    Easier would be an aftermarket CFI 2 bbl set up.
                    BTW crank is different to
                      What they said. Fits, but probably not worth the effort. I believe the ports on the 255 heads are a fair bit smaller than 302 stuff so you'd probably run into some odd turbulence problems because of it.
                        What heads did the 255's use?
                        -Phil
                          Terrible. I honestly don't know though.
                            FROM WHAT i have looked up they were smaller and more of an oval port.
                              X2
                              Heads would need port matched at minimum. And they have itty bitty valves? 1.68 intake is what my reference guide says. The cranks are lightweight/hollow or something silly like that. Who wants a hollow crankshaft? Ford probably made junk special heads just to reduce power to keep the crank alive.
                                All of the above makes sense. Kind of like my half-baked idea to EFI swap my Lima 2.0.
                                I was thinking MAF SEFI because Speed Density CFI (or even Speed Density multiport) might be a bit upset about all that mysteriously missing displacement.
                                Not like I have a 255, or would do this, but it was a thought that occurred to me.
                                | Junkyards
