Ye man
Emissions Advice / HC levels
Originally posted by gadget73 View PostIf it was rich, it should be high HC and high CO. Just high HC indicates a misfire, which could be ignition related or lean fuel mix.
Originally posted by gadget73 View Postadvance the timing to 10 btdc. Late timing will contribute to incomplete combustion.1992 CVLX. 5.0 HO/GT40P/T5/3.73/trak-lok with bolt ons. 02 front CVPI setup, rear HPP setup, CVPI shocks around, F250 radiator, e-fans, and the power of 3G. 15.92@89mph, 2.4 60', 4700' elevation (5500' DA) with 3.08 open rear and the old oil chugging 289. RIP.
yep, no NOx checks anymore since they did away with the dyno roller thing. Its just an idle and high idle (like 2000 rpm) check. We get a printout with HC, CO and CO2 figures only. If it still has the field for NOx, it usually says N/A.86 Lincoln Town Car (Galactica).
Sorry for the delay, been trying to get stuff done on the car and was having problems getting on here with my password. I finally got a chance to put a new set of wires on, the timing was advanced to 10btdc from 8, and my Dad tossed from Marvel Mystery oil in 2 different fillups. The car passed though I didn't get a print out this time. The HC numbers dropped to about 109ppm at idle so a big difference there. Considering the change from the first to the second run I'm guessing there was something going on with the wires, though the timing being off probably didn't help any. Next big problem I'm looking at is my the pass hinges on my tudor got bent so that should be fun. Thanks for the help everyone.sigpic
1986 Grand Marquis LS 2 Door
Originally posted by 86GmLsCoupe View PostSorry for the delay, been trying to get stuff done on the car and was having problems getting on here with my password. I finally got a chance to put a new set of wires on, the timing was advanced to 10btdc from 8, and my Dad tossed from Marvel Mystery oil in 2 different fillups. The car passed though I didn't get a print out this time. The HC numbers dropped to about 109ppm at idle so a big difference there. Considering the change from the first to the second run I'm guessing there was something going on with the wires, though the timing being off probably didn't help any. Next big problem I'm looking at is my the pass hinges on my tudor got bent so that should be fun. Thanks for the help everyone.
10degress before top dead center is stock on these cars.
cool. legal is good.86 Lincoln Town Car (Galactica).
