Hi!
So in the course of tearing down my engine, I've undone many of the repairs that I did this past summer. Oh well: learning experience and all that
One thing was worrisome. Everything I'd touched, was loose. The valve cover bolts? god, they came out just with the socket, no ratchet for leverage. No wonder it started leaking this winter, just months after changing the gasket
The water pump bolts? Tight, but 10-15 lb-ft would not be an underestimation. Scary.
The starter motor? One bolt came out just between my finger and thumb! The other, as tight as the water pump bolts.
I would swear at the time that I'd tightened them! And yes, more than 15 lb-ft!
Last week a prof advised me to drive around for 50 miles, and when I pull back into the shop to change out my sacrificial oil (to clean out shop rag lint and assembly lube), check and retighten the header bolts: it's so hot there that they're bound to have loosened up. Seems like sound advice.
But could the same have been true for other accessories that aren't quite as close to the combustion, like a starter motor or water pump bolts???
Now, when I took out most of these bolts, they were frozen, so when I put the new ones back in, I frequently used antiseize. Could that be the cause of my troubles? I know I used it on the water pump bolts for sure. Should I use thread sealant instead?
Should I even be using loctite on some of these?
To be sure, In theory I'd hate myself 10, 15 years from now, but to be reasonable this might be the last time any of these components are changed again.
thanks!
-Bernard
thanks!
-Bernard
