is there a way to fool these sensors after removing smog pump and related parts and not throw codes 94,44.
tab,tad sensors
No, and BTW, they're solenoids, not sensors, they only allow vacuum to pass through different passages to vacuum valves to allow air to be pumped into the heads. The sensors are the O2 sensors, and you really can't do anything about it. Those codes are ignorable. Sadly though, when that stuff is removed, it also removes the EECs testing of the O2 sensors.
You could however, if you felt so inclined, spend money on tuning stuff and turn that stuff off. So the codes aren't triggered. This can be achieved either by means of a chip or a tweecer/quarterhorse. Only time you'll get those codes is during a self test, and they don't trip the check engine light, so I wouldn't personally worry about it.Last edited by 86VickyLX; 04-04-2011, 09:41 PM.
