stupid PCV question
    Originally posted by Merc302 View Post
    i kinda thought the screen should always be replaced as well...
    for what the stuff costs you should replace it every time the upper intake plenum is off imo
      the factory part number Motorcraft has no elbow. Some catalogs list a superseded part, which is identical but comes with the removable elbow. The OEM PCV valve is actually made of plastic, and for a reason. The metal ones will sometimes make a clattering noise as the little disc in there dances around. Plastic ones are quiet. More granny tuning. The stock valve is some sort of phenolic material, which is impervious to just about everything including nuclear bombing.
        time to stock up on PCV valves then, huh?lol and yes, the metal valves can be stupid noisy
          maybe that's what's clattering on my 88... and my 93... hmm.
            Mine rattles so much it sounds like two skeletons screwing on a tin roof
            1988 Signature Series Town Car
              ^^hahahaha
                :lol:
                that's an interesting visual there.
