stupid PCV question
    stupid PCV question
    You don't need to use the little elbow that comes with the PCV valve, do you? I don't see why you would but I thought I'd ask you guys given the fact that I can wire a distributor backwards and not notice.
    to clarify:
      not on your SEFI engine. that elbo is intended for the older carbed and CFI engines that have the PCV valve it the rocker cover oil cap.
        I figured it was for the valve cover type breather - thanks man!
          no worries young blood! lol
            we can just cap off the second hole?
            I did my pcv valve over the summer, but actually now I can't remember what I did... hope it's not been blowing oil all this time
            What did another poster mean by the "pcv trifecta"? It's just that one valve, right? Or are there two other components to address?
              Take it off the valve. The trifecta, I would imagine would be the PCV valve, the PCV screen and the PCV grommet. All should be replaced
                Odd, none of the motorcraft filters I've bought to date have come packed with the 90º elbow. Just a straight pcv valve in a sealed bag.
                Alex.
                  The generic ones you get from Fram at Wal-Mart have the elbow.
                    Last one I used had the elbow as part of the valve, couldn't remove it. I can't remember what brand it was though.
                      The one I picked up at Carquest was made with the 90. I actually didn't try to remove it...I was replacing the rubber hose anyway and had a 90 to go down to the factory configured valve. I just rotated it to line up to the Carquest valve.
                        Pulled off of the one i used on my car. I'm not dealing with any more plastic than i need to.
                        In an unrelated note, that pcv valve is used on aeros too and uses both fittings.
                          yeah the 95 has the same one in the valve cover
                            Take a look at the image in post 2, motorcraft pcv.
                            Alex.
                              i kinda thought the screen should always be replaced as well...
                              1985 Mercury Grand Marquis ls-302 CFI
                              Carb swap planned .
                              c90 heads
                              475 lift cam
                              Weind stealth intake(looking for reasonable air gap or manifold for 2bblsidedraft)
                              Built aod(want c6 tryin to fin vac mod model)
                              331 stroker kit
                              Work in progress
