Originally posted by vitals_fading
View Post
Everyone Should Look At This Please
My '79 TC had starting issues in cold/damp weather last year. After replacing the cap and rotor, there were no more issues. That being said, all the other tune-up related items have been replaced within the past two years, which certainly helps!'79 Continental Town Car
'90 Crown Victoria LTD
'94 Crown Victoria
Originally posted by zoomie View Postdistributor shot is a good excuse to upgrade if you have the moneyhttp://www.partsgeek.com/gbproducts/...ek+Google+Base
yea i agree, waste of money
No need to upgrade to a dist. like that unless you plan to do alot of racing. A reman. distributor will be fine. An MSD box to control your current distributor would be a better investment.
But, an MSD distributor is manufactured to closer tolerances. You have a billet shaft, a better alloy driven shaft, etc. That translates to more accurate spark. However, OEM stuff, and even a properly remanufactured distributor is perfectly fine for even a pretty hot build.
I was going to use an MSD dist. in my car, but decided the $240 (steel gear, no vac advance) was too much, for too little. Plus it would ruin my plans to keep the engine looking pretty stock. But when I build an engine for this car, its definitely going to get an MSD dist.**2012 Ford Mustang Boss 302: 5.0/ 6 spd/ 3.73s, 20K Cruiser
Originally posted by 79lincolnlover View Post89 townie, mild exhuast up grades, soon to have loud ass stereo....
The only crankshaft position sensor I know of is in the distributor, but it's not called that. PIP and it's a signal from the TFI module to the computer. If it doesn't see this, there's no fuel delivery. Now this could be caused by a dead TFI module, a dead pickup, or both.
CFI has one though, doesn't it? I thought one of the oddball engines (CFI or 5.8) had a CKP. Or am I just crazy?Originally posted by gadget73There is nothing more permanent than a temporary fix.
Gotcha. I knew I'd read about it somewhere.
And now back to your regularly scheduled programming.Originally posted by gadget73There is nothing more permanent than a temporary fix.
