replacing engine: what else likes to rust & rot, while I've got it pulled?
    Hi--
    Been starting lots of threads fretting over my engine rebuild.
    Will be ordering parts tomorrow, pretty much all engine related.
    On my short list, I do have a pipe related to the egr which rusted through, to replace (currently held with jb weld, hahaha), and the heater hoses, as the last remaining original coolant hoses and long due for dry rot and critical failure.
    Already did the starter motor and water pump.
    Considering adding a trans cooler.
    Oh, and the front seal on the torque converter leaks. Also a great time to do that too.
    Maybe I should just get a new car while I'm at it...
    Anyway. Wondering what else I've overlooked. Any item that's tricksty to get to, that'll be hella easier to replace while I've got the engine out, and isn't likely to last 30 years without issue?
    I don't want to do this engine swap, and 3 years from now have some $.50 plastic line hidden behind the engine rupture, and curse myself bitterly for not having done that today!
    ...for example, any "vacuum line kit" to buy and just do all the vacuum lines preemptively, or would I be wasting my money and best just to replace when and as they fail?
    Be generous with your list; I'm already spending hundreds on this project, another hundred more in preventative maintenance will not be a bad thing.
    thanks!
    -Bernard
    torque box is probably rusty as shit
      frost plugs!!! front and rear of heads along with block... hell... i wonder if the racing gears would last longer than timing chain would?
      Addicted to 86-87 Panthers
        anything that looks like it could fail should be replaced....
        1988 MGM GS - Preferred Equipment Package 172A; InstaClear
        1994 MGM GS Montigua
        2002 Mustang GT Coupe
          If you replace the pump seal, then do the tail seal as well. Will you be taking the transmission out with the engine?
          If so, turn it over and put a kit in the vb.
            Originally posted by BerniniCaCO3 View Post
            Hi--
            I don't think that pipe you're talking about belongs to the EGR (you have a SEFI engine, right?). Does it run from the cats to the smog pump or from the heads to the smog pump? That would be the smog pump system.
            ON SEFI engines, the EGR is wholly internal to the intake.
            If you DON'T have to pass a visual inspection, remove the smog pump and put the shorter belt on (500k6 or 560k6, one of them is the regular belt for the alternator, etc, the other belt is for the shorter passenger belt). Then, remove the pipe from the back of the heads, cut the ends off, flip them over to cover the holes on the back of the heads. Remove all extraneous pipes. Then, cut the pipes off of the cats, pinch them shut and weld them shut (or JB) so they don't leak, and remove all other piping. Boom, no more smog crap.
              this is the pipe that's rusted: http://cgi.ebay.com/ebaymotors/ws/eB...ht_2137wt_1002
              is that smog, and.. what is the smog pump/ what does it do anyway? Better fuel economy if removed?
                when your catalytic converters are cold air is pumped in from the smog pump to heat them more quickly. similar to a blast furnace.
                smog pumps are only for cold start emissions.
                  don't they also blast air into the exhaust ports of the heads to sort of pre-burn stuff before it hits the cats?
                    Flow restricting smog humps FTW!
                      stupid question related to that: can you remove the humps as far as restriction and still leave a reasonable hole if you wanted to still have the smog pump working? Or are you left with a gaping hole you need to fill in or something?
                        IDK, their kind of angled and junk. I wonder how'd they work if they still had air going through them after they were ground down.
                          it's amazing that pointing the flat side against the direction of flow ever seemed like a good idea.
                            Removing the bumps was an old trick from before the availability of aftermarket heads. It does make a difference, just smooth them out, but don't get crazy. Also gasket match the exhaust port, but leave the intake ports alone & you will feel the difference in the Butt Dyno and see it in your timeslips...
                              ass dyno FTW. though it may not be an 'accurate measurement tool' even though my ass is calibrated, just like my wrist. who needs torque wrenches??
                              grandpaslincoln!
