valve cover identification
    I just picked up an ultra cheap set of finned aluminum valve covers. The only markings are on the underside and they say
    CAL CUSTOMS
    GARDENA CALIF
    40-1017
    Can anyone give me any information based on that? All I can really tell is that they're in good shape; need a painting; have the correct SBF bolt pattern
    These covers look a little tall for stock EFI applications so I'm probably going to need a spacer...but these covers look damn nice! Only $20.
    Like these?
      similar but not exactly like them. they're definitely a lot older.
        that's them exactly. slightly cleaner than mine
          does anyone have a stock valve cover nearby that they could measure?
            see mine are much dirtier
            also what part of the vc should i be measuring to see if they'll clear the intake plenum?
              I never really heard of them before until today until I went to buy a old parts 302 for $50. The 302 came with a pair of old dirty Cal Customs finned cast aluminum valve covers and a old F4B Edelbrock intake. I have done some searching on the internet but can only find new ones for sale. The...
                Way back in the day( RE: 1968-1975 ) They were THE covers to have . Nice find
                1988 Signature Series Town Car
                  hah! I still can't believe just how much translates over the DECADES to our '90s era cars, all the parts still fit together!
                  SO much better than these imports, where you need a part only from this 2 year span, but wait-- they changed midyear, so check the part number: it's only a 1.5yr span. And it has to be the limited edition version, ohhh, so close: but v6 six limited edition of that year only.... and it had to have rolled off the assembly line on a 1/2 moon night in a winter month....
                    well our engine "family" has been around since the 60s...maybe 50s but I think early 60s. 50s were y block I think
                    but yeah...I'm pretty sure I'm going to need a 1/2" spacer....does anyone think I would run into hood clearance problems with a full 1" spacer? Might get one of those just to be on the safe side (I don't want to buy a 1/2" spacer and find out it's not enough).
                    the wicked price I got on these justifies spending a bit on a spacer I think!
                      cool! thanks for the offer of the stock valve covers, btw.
                        will that work in these covers? i got a plug for the drivers side but need something with a breather tube for the passenger side. canadian tire didn't have any.
                          I'm running a 1" on my '87 C.V. C.S. with an Explorer intake. The EGR hose got chopped by a hood support rib. I massaged the rib w/a ballpeen & it seems to fit ok now.
                            yknow...FUCK TOYOTA.
                            1985 Mercury Grand Marquis ls-302 CFI
                            Carb swap planned .
                            c90 heads
                            475 lift cam
                            Weind stealth intake(looking for reasonable air gap or manifold for 2bblsidedraft)
                            Built aod(want c6 tryin to fin vac mod model)
                            331 stroker kit
                            Work in progress
                              The reason all this stuff fits is because they made the same basic engine for 50 odd years. The first Windsor motor came out in 1962 and it didn't really change much till 2001 when it went out of production. Look up smallblock Chevy stuff sometime. They made those forever too.
