bolts to mount 302 on engine stand?
    Hah, remembering the 2.2 cavalier engines we mounted my last class-- no one had the right bolts, and someone in my team crushed the aluminum distributor gear with a bolt that was too long
    Anyone have handy the thread size, and suggested bolt length, to pick up at home depot to mount this 302 block on a stand?
    And, the block isn't so very heavy, maybe 150lbs: do I still want grade 6 or maybe even grade 8 bolts?
    ...or if metric, whatever strength standards system is used there.
    thanks in advance!
    -Bernard
    Use bellhousing bolts with spacers to take up the extra length. Nothing better than what holds the transmission to the engine.
