mass airflow sensor?
    Hi!
    Picked up an explorer intake yesterday, guy also threw in a cold air intake.
    ...sorry to interrupt myself here, but there's the intake MANIFOLD, and then there's the intake ..."tube." snorkel. Does it have a more technical name, just that length of rubber and plastic that holds the filter?
    Anyway, this cold air intake included a metal mounting post and and a largish diameter ring with a mass airflow sensor built into it, the kind I'm familiar with from my '01 volvo, and I think which most cars now have.
    Might be the newer format from the '98 explorer, where this was pulled from.
    Does this hook right into our stock system one way or another? Do we have mass airflow sensors at all even, and if so, where are they located?
    Finally, I was thinking about EGR (which I would be disabling if I use this intake).
    I'm curious: does the computer turn the egr on and off? Is the mass airflow sensor before or after the egr inlet? Because if it's well in front of the egr entrance, then doesn't that mean that you'll run rich because the blended exhaust gases have so little oxygen left?
    Or if the computer knows that it's turning on the egr, and I've just sort of left it unhooked, then the computer might try to limit the fuel injectors, thinking there's more exhaust gas (and less oxygen), and I'd run lean?
    no mass air sensor exists on a stock Vic. The EFI runs on speed-density logic, which is basically derived from engine speed (rpm), air density (air and coolant temperature sensors) and engine load (MAP sensor, reads vacuum) along with input from the throttle position sensor and feedback from the oxygen sensors to make an educated guess at how much air the engine should be using, and using that info to determine how much fuel to give.
    ECM controls the EGR valve to open and close it. EGR valve is in the intake itself, mass air meter would live between the throttle body and the air filter if you had one. The ECM will know if the valve is opened based on feedback from the position sensor. If it calls for the egr valve to open and it doesn't see it actually open, the fuel mix is not affected.
      Our cars have no MAF (except 90-91 California cars), just leave it in the tube and you can tell people it does, lol. You can do a MAF install with a different ECM if you want, so hang on to it.
      EGR stuff happens past the throttle body, so it has nothing to do with the air tube. You can run fine without the EGR operating, if anything it might wind up a little rich.
        why rich?
        And yes-- I've got it, and I'm changing the ECM anyway just for the HO conversion: can I pull the newer explorer computer and make use of my new MAF?
        I just searched the archives for "maf install" and didn't find anything... can you give me some pointers? Or know of a guide/ previous thread that covered it?
        And hey, nothing wrong with an obd-ii upgrade, if it's not too byzantine!
          Originally posted by BerniniCaCO3 View Post
          why rich?
          No.
          Unless you come up with a setup similar to Super Lincoln, where you run all explorer accessories, use the harmonic balancer from that engine and whatnot. Then rewire the whole car, and add all of the bullshit that comes along with OBD-II. The computer will be pissed that there's no transmission to control.
          Get a Mustang Mass air computer and a use your explorer mass air meter. Add the wiring for the mass air sensor to your stock harness, and plug in your explorer meter.
            with no EgR, it doesn't so much run rich, as it does not lean out the fuel mix at cruise speed. With EGR, there is less available oxygen, therefore less fuel is needed to ensure that the engine does not detonate. Basically it gives you a smidge of fuel economy while dropping NOx emissions.
              which years mustang have a mass air computer, but, aren't yet obd-ii? I know obd-ii is '96+, so I guess the real question is: ??-'95 is the computer I want?
              ...sounds simple, and much simpler than the explorer computer
                89-93 is the most compatible. the A9* series. you ideally want one from an automatic car, and not the F3Z or whatever it is the 93 Cobra came with.
                  According to FFI, I'd assume any of these would work good.
                  A9M 5.0 89-93 Mustang MAF / Auto (see note 1)
                  A9P 5.0 89-93 Mustang MAF / Auto (see note 1)
                  C3W 5.0 89-93 Mustang MAF / Auto (see note 1)
                  C3W1 5.0 89-93 Mustang MAF / Auto (see note 1)
                  A9T 5.0 89-93 Mustang MAF / Auto (see note 1)
